Password to avoid changes
It's always an idea that I have since a few time but I wonder if it will be possible to put a password to avoid change any workflow. First it will protect to any change but it will protect the workflow maker.
Maybe install password manually after finishing edit node and enter password to begin the first edit node.
Yes Steinar I already told you about it but maybe it will be useful for someone else :)
Thanks and cheers.
Re: Password to avoid changes
Hi Benjamin :-)
Thanks for the notification. Actually, FFAStrans used to have a working mechanism for protecting workflows but it broke several versions ago and it did'nt recieve any TLC after that. So, the options are already there under workflow properties -> Special but is not working. SO, I'm fixing it now so it will be OK again for the next release.
Hello Steinar,
Really good news thank you very much!
I wait for that with real pleasure ;)
Cheers
