0.9.1 DNXHD Encoder Issues
as1000
Post by as1000 »
I'm noticing that as I move my workflows to 9.1 I'm seeing some issues in the way the DNXHD node encodes.
So I'm getting a single file being output as an .mxf. MediaInfo reports this as an op1a file. When checking the "create avid project structure" I get no files being output but a success in the monitor status for that job. Upon inspecting the log file I'm seeing an error in the dnxhd when I use the create avid project strucutre option.
Input #0, mxf, from 'c:\.ffastrans_work_root\20180601095023\20180601-100445-860-0587B9F9C851\~20180601-100506-334-B4F9763A4478.mxf':
Metadata:
uid : adab4424-2f25-4dc7-92ff-29bd000c0000
generation_uid : adab4424-2f25-4dc7-92ff-29bd000c0001
company_name : FFmpeg
product_name : OP1a Muxer
product_version : 58.13.102
product_uid : adab4424-2f25-4dc7-92ff-29bd000c0002
modification_date: 2018-06-01T14:05:07.000000Z
material_package_umid: 0x060A2B340101010501010D001395F65552947134A995F6550052947134A99500
timecode : 00:00:00:00
Duration: 00:01:16.91, start: 0.000000, bitrate: 148782 kb/s
Stream #0:0: Video: dnxhd (DNXHD), yuv422p(bt709/unknown/unknown, top first), 1920x1080, SAR 1:1 DAR 16:9, 29.97 fps, 29.97 tbr, 29.97 tbn, 29.97 tbc
Metadata:
file_package_umid: 0x060A2B340101010501010D001395F65552947134A995F6550052947134A99501
Stream #0:1: Audio: pcm_s16le, 48000 Hz, 4.0, s16, 3072 kb/s
Metadata:
At least one output file must be specified
,Frames,0)
=PROC=> 2018-06-01 10:05:53.011 on Avid DNxHD@DESKTOP-B1TNMPE, PID: 16348 -> _WaitForResources(Waiting for resources...)
=PROC=> 2018-06-01 10:05:55.303 on Avid DNxHD@DESKTOP-B1TNMPE, PID: 16348 -> _WaitForResources(Waiting for resources...) ==> Resources obtained.
=PROC=> 2018-06-01 10:05:55.925 on Avid DNxHD@DESKTOP-B1TNMPE, PID: 16348 -> ProcessorEnd_Routine(enc_av_dnxhd 20180601-095219-801-5761923f77d8)
=PROC=> 2018-06-01 10:05:56.099 on Avid DNxHD@DESKTOP-B1TNMPE, PID: 16348 -> Ending process...
=PROC=> 2018-06-01 10:05:56.134 on Avid DNxHD@DESKTOP-B1TNMPE, PID: 16348 -> =================================================================================================================================================================================
=PROC=> 2018-06-01 10:05:57.079 on Folder@DESKTOP-B1TNMPE, PID: 8288 -> Ticketfile is "C:\Users\ajs\Downloads\FFAStrans0.9.1\Processors\.cache\tickets\x20180601-100556-783-E9BF54387A26_20180601095023~loc~DESKTOP-B1TNMPE~20180601-100445-860-0587B9F9C851.ini"
=PROC=> 2018-06-01 10:05:57.090 on Folder@DESKTOP-B1TNMPE, PID: 8288 -> Source is c:\.ffastrans_work_root\20180601095023\20180601-100445-860-0587B9F9C851\~20180601-100506-334-B4F9763A4478.mxf
=PROC=> 2018-06-01 10:05:57.108 on Folder@DESKTOP-B1TNMPE, PID: 8288 -> Creating work dir: c:\.ffastrans_work_root\20180601095023\20180601-100445-860-0587B9F9C851
=PROC=> 2018-06-01 10:05:57.119 on Folder@DESKTOP-B1TNMPE, PID: 8288 -> Registering abort check...
=PROC=> 2018-06-01 10:05:57.146 on Folder@DESKTOP-B1TNMPE, PID: 8288 -> Executing ini: "dest_folder 20180601-095225-641-d3cd4e9f57af"
=PROC=> 2018-06-01 10:05:57.159 on Folder@DESKTOP-B1TNMPE, PID: 8288 -> Executing sys: "dest_folder 20180601-095225-641-d3cd4e9f57af"
=PROC=> 2018-06-01 10:05:57.170 on Folder@DESKTOP-B1TNMPE, PID: 8288 -> ProcessorEnd_Routine(dest_folder 20180601-095225-641-d3cd4e9f57af)
=PROC=> 2018-06-01 10:05:57.179 on Folder@DESKTOP-B1TNMPE, PID: 8288 -> Job completed without errors.
=PROC=> 2018-06-01 10:05:57.195 on Folder@DESKTOP-B1TNMPE, PID: 8288 -> _EnumIfNewJob() with current queue:1
=PROC=> 2018-06-01 10:05:57.222 on Folder@DESKTOP-B1TNMPE, PID: 8288 -> Ending process...
=PROC=> 2018-06-01 10:05:57.232 on Folder@DESKTOP-B1TNMPE, PID: 8288 -> ==============================================================================
as1000
Re: 0.9.1 DNXHD Encoder Issues
Post by as1000 »
Tested on another machine same result.
Hello as1000
You're right no output file in output folder...Same thing when use XDCAM and check avid structure.
Only solution for now, go back to 0.9.0.4.
If you don't have this version, tell me I will send it to you :)
Cheers
Hi all and thanks for the report. I've found the bug a patch will be released hopefully later today.
Sorry for the inconvenience. A patch is now ready on the website. Thanks for reporting! :-)
Thanks Stenar, lightning-fast!
I will test that ;)
