I think I could use this good feature in 0.9.0 in maintenance menu of workflow : Remove monitored file record from history cache.
Now, in 0.9.0.3 it seems inoperative...
I create a simple workflow (folder>custom ffmpeg encode>delivery>delete original by command executor)to check and when I drop again the same file nothing happens.
Maybe I'm wrong but I really believe It works before.
Please, can you tell me Steinar?
Thank you very much.
Problem cache in 0.9.0.3?
Re: Problem cache in 0.9.0.3?
I'm sorry but the option was actually removed but the replacement was never documented. This will be fixed for the next release. Each history record is a seperate file stored in the new "%s_cache_record%" variable. So you need to use the "Command executor" instead:
%comspec% /c "if exist "%s_cache_record%" del /f /q "%s_cache_record%""
This should work with the current 0.9.0.3 release, it just lacks the documentation for it.
Great, it will be very useful for me!!!
I must say avoid cache can be very important for specific workflow so good news if you can fix it in next release.
Thanks for the solution.
PS: YES, the del %record_cache% works fine
thanks!
