Watch folders don't run anymore
jfou1987
Post by jfou1987 »
Hi !
We have 2 PC with running FFAstrans on version 0.8.2. Working fine since last week. They stopped booth to work without any reasons.
So I decide to format one of them, running on windows 10.
I installed 0.9.0 version. But when I tried to do a simple "move" action (monitor/folder and moving the file to deliveries/folder) on the desktop to verify the good working of the system, nothing happened...
I don't know what I can do to make my FFAstrans working again.
Is there everyone, who already had a same trouble ?
Kind regards
Jfou1987
Re: Watch folders don't run anymore
Hi Jfou1987, thank you for using FFAStrans and welcome to the forum!
Make sure your antivirus does not screw with these files:
FFAStrans\Processors\processors.exe
FFAStrans\Processors\def_runner.exe
FFAStrans\Processors\exe_manager.exe
Unfortunately AVs have a tendecie to flag FFAStrans-files as suspicious. They are false positives so you need to exclude FFAStrans from your AV.
jfou1987
Post by jfou1987 »
Hi ! That was the key ! Stupid windows defender .... But i didn't received any alert.
Windows 10 working fine now.
but I stil have trouble with the windows 7. Encoding mxf AVCINTRA50 file is freezed to "preprocessing with MEncoder" and failed after a while.
I use the av media decode (intelligent preparing for audio and video) I tried to change setting in the media decode. but still the problem.
Do you have an idea ?
Kind regards
Hello Jfou,
I tried folder>AVCintra 50 > deliver and it's ok.
Could you tell me why you use av media decode ? I think it's only necessary when you want to use filter.
What kind of video file have you in source file?
thanks.
jfou1987
Post by jfou1987 »
Ok found the problem.
I re-installed FFastrans and now it's working fine :-)
Great! :-)
