Windows Defender prevent FFAStrans 0.9.0 from running
screenshaper
Post by screenshaper »
Windows Defender prevent FFAStrans 0.9.0 from running.
Win10 fresh install.
The files "Processors\processors.exe" and "Processors\exe_manager.exe" are blocked and quarantined as Trojan:Win32/Fuerboos.B!cl by Windows Defender as soon as you extract files from the download package (FFAStrans0.9.0.7z).
The file "Processors\processors.exe" is blocked also as Win32/Tilken.B!cl
Re: Windows Defender prevent FFAStrans 0.9.0 from running
Yes, well that's the continous problem; False positives. It's almost impossible to prevent this. Normally you should be able to override the AV.
