By default x64 AviSynth version is used
kibi
Post by kibi »
In case of workflow without A/V Media Decoder (when it's necessary to process AVS files) FFASTRans tries to use x64 version of FFPROBE.exe
That's why it's impossible to use x86 dll AviSynth plugins. It would be nice if x86 version of FFPROBE and FFMPEG have the priority.
Alexander Sorkin
Re: By default x64 AviSynth version is used
Thanks for pointing out this issue, Alexander! I will have a look at it as soon as possible.
kibi
Post by kibi »
Hi, Steinar!
I have successfully migrated my AVS scripts to AviSynth+ x64, thougth is was rather tricky, since I couldn't find working AVSPMOD for Avisynth+ x64.
There is a very helpful function SetLogParams, to log all the internal processing of AviSynth+:
SetLogParams("F:\Test-zone\avisynth.log", 4)
I've find in logs, that AviSynth+ couldn't recognize a standard function like "ImageSource" and assumed that it was the plugin loading issue. That's why added to the top of the scrips:
ClearAutoloadDirs()
AddAutoloadDir("F:\FFASTrans_0.8\Processors\ffmpeg\x64\plugins+")
LoadCPlugin("F:\FFASTrans_0.8\Processors\avs_plugins\ffms2\x64\ffms2.dll")
LoadCPlugin("F:\FFASTrans_0.8\Processors\avs_plugins\autocrop\x64\autocrop.dll")
and now it works like charm! Thought I have to find x64 version of all the used plugins.
So it would be nice to have an option in workflow properties, to use x64 / x86 code with three variants - "Prefer x86 code" (in case of rare 32-bits plugins), "Prefer x64 code" and "Automatic choice" (as it is now).
Alexander Sorkin
That's great! :-)
It's a good suggestion on the x64/86 options and I will really consider it. Thanks! :-)
kibi
Post by kibi »
I would like to share a "cross platform" code, is able to work in any environment (32-bit and x64):
Findstr(VersionString(), "x86_64") != 0 ? Initx64() : Initx86()
function Initx86()
	SetLogParams("F:\Pipeline\Logs\avisynth.log", 1) #1: LOG_ERROR / 2: LOG_WARNING / 3: LOG_INFO/ 4: LOG_DEBUG
	ClearAutoloadDirs()
	AddAutoloadDir("F:\FFASTrans\Processors\ffmpeg\x86\plugins+")
	LoadCPlugin("F:\FFASTrans\Processors\avs_plugins\ffms2\x86\ffms2.dll")
function Initx64()
	ClearAutoloadDirs()
	AddAutoloadDir("F:\FFASTrans\Processors\ffmpeg\x64\plugins+")
	LoadCPlugin("F:\FFASTrans\Processors\avs_plugins\ffms2\x64\ffms2.dll")
It could be easily adapted for AviSynth 2.60 and any other versions, for example:
Findstr(VersionString(), "AviSynth 2.60") != 0 ? Init260() : stub()
Alexander Sorkin
