I've noticed when putting a watch folder on a NAS that large files are being processed while they are still copying. This happened with a 4 gig and a 16 gig pro res file. The workflow that I'm putting through is a bitc watermarked dvd iso.
What usually happens is that I get a lot of "Could not recognise content in file" errors and new jobs just keep popping up. Once the file has finished copying, it then puts through around3-5 identical jobs, but only one makes it through as the others have identical output names.
Is there some option I'm not selecting?
Thanks,
Kieran.
FFAstrans processing files while they are still copying
Re: FFAstrans processing files while they are still copying
It's not a bug, it's a feature
Please check the "Check for growing files"-option in the workflow setup and let me know if that helps.
Indeed! It worked perfectly, thanks Steipal!
