movalex
Posts: 36 Joined: Thu Feb 06, 2020 2:23 pm
Post
by movalex » Mon Mar 16, 2020 4:22 pm
Hi!
I dunno whether it is a bug or some Windows locale glitch, but in FFA > 1.0.0 Resize node presets are shown like this:
in v. 0.9 on the same machine resize presets are correct:
Posts: 1704 Joined: Sat Feb 08, 2014 10:39 pm
Post
by admin » Mon Mar 16, 2020 7:16 pm
Hi movalex,
Hm, this looks like some local issues. We might have to revert to using a straight "x" instead of the small "ˣ". Anyway, thanks for notifying. I might want to send you a test build with some modification so you can test, if that's ok?
movalex
Post
by movalex » Tue Mar 17, 2020 2:40 pm
Sure!
Also please check all the places where small x is used.
Post
by admin » Wed Mar 18, 2020 12:16 pm
Hi movalex,
Can you please try the attached file? Just rename to .exe
FFAStrans .txt
(2.27 MiB) Downloaded 852 times
movalex
Post
by movalex » Wed Mar 18, 2020 2:08 pm
thanks, this fixed the issue:
Post
by admin » Wed Mar 18, 2020 2:35 pm
Great, thanks!
movalex
Post
by movalex » Wed Mar 25, 2020 10:35 am
BTW 1.0.0.4 will now crash if I try to edit my old resize nodes:
Post
by admin » Thu Mar 26, 2020 12:04 pm
Hi movalex,
Can you please try this patch preview?
FFAStrans1.0.0.4_prev.7z
(2.39 MiB) Downloaded 900 times
Vladimir
Posts: 21 Joined: Fri Mar 27, 2020 1:38 pm
Post
by Vladimir » Thu Apr 02, 2020 1:47 pm
i see the same bug in FFAStrans 1.0.0.3. Windows russian locale.
The new patch (1.0.0.4) works normal, no crash.
