FFAStrans 1.4.0.1, Monitor growing file issue
artjuice
Re: FFAStrans 1.4.0.1, Monitor growing file issue
Post by artjuice »
Ok, thx, i will do it with 1.4.0.4 & 1.4.0.5 and send you logs as soon as i reproduce the issue.
artjuice
Post by artjuice »
Hello @emcodem,
Here you go - def_log. Files name = ftest (#).MXF, size 9-15GB per file.
No one file was picked up when a copy process was started for them to watchfolder, only when i paused copy - file was detected (ftest (17).MXF).
FFAStrans 1.4.0.5
def_log.zip
(474.47 KiB) Downloaded 1852 times
artjuice
Post by artjuice »
UPDT
Just tested 1.4.0.1 - all work fine, all files picked up.
I was look also on 1.4.0.3, but found a bug - variable %i_mon% don't work as expected, it set mouth as 4, in all versions before and after it's - 04 :D
P.S. i found one more bug in 1.4.0.5 with Audio extraction Encoder :D will add bug report soon.
Hi, artjuice :-)
I think I've tracked down the root cause why you files was not picked up. The logs helped! Can you please try this new def_runner.a3x attached?
I'm also keen to know what the audio extraction bug is, if you have some more insight on that ;-)
Thanks for reporting bugs!
def_runner.a3x
(135.57 KiB) Downloaded 1656 times
artjuice
Post by artjuice »
Hello @admin
Sorry for the delay, just started testing, and as for now there were no problems with big files.
And about "audio extraction bug" what logs do you needed - i will collect them and post in topic with "Audio issue".
Thx
Hi artjuice,
Well, first I nees a description of the bug. Then the job log of a job that has the problem.
