Generic MPEG in FFASTRANS 1.1.0.2
Wahyu
Re: Generic MPEG in FFASTRANS 1.1.0.2
Post by Wahyu »
admin wrote: Tue Nov 17, 2020 8:02 pm Hi Wahyu,
I'm really not able to reproduce with the 1.1.0.2 version. I've tried running through your workflow but it seem to work as expected. I think you must run a job that's failing and send the complete work cache folder for further investigation. The log you sent did not show enough unfortunately.
Can you please make sure this option is enabled and when you have run a job that outputs an .avs file, you need to right click on the monitor and select "Open work folder...". Zip it and send it.
Thanks.
attached generic mpg logs and H264 logs. I send 2 logs as a comparison because if I replace encoder to H264/DVD or other, workflow works.
Wahyu
work if Replace enc to H264.zip
(13.62 KiB) Downloaded 571 times
Wahyu
Post by Wahyu »
Finally I understand, why is my workflow problematic for generic mpeg. After I checked it turned out that processor.a3x was not compatible with version 1.1.0.2. I compare it with re-downloading.
Maybe there is something wrong when replacing it.
thank you All, for helping my problem
Oh no, you mixed files from different versions??
Wahyu
Post by Wahyu »
what I see like that, I do not know when it happened and maybe accidentally replaced because so far I am still using version 1.0.0. and the plan will use 1.1.0.2 to test the generic mpeg.
