Closed Captions - 608/708
john
Post by john »
I just want to say Thanks -a- million. :D
Does FFAStrans Support Closed Captions? Can you encode files with a 608 or 708 Captions?
if so, Can the software take a .scc or a .mcc closed caption file format?
Re: Closed Captions - 608/708
Hi john, thank you for using FFAStrans and welcome to the forum! :-)
FFAStrans has no inbuilt functionality to use CC but I know that ffmpeg has some CC support. So you would have to use the "Custom FFmpeg"-encoder node to utilize it.
But I will add this request to my list. Thanks!
Timfx
Post by Timfx »
What John is asking for is exactly what I am looking for. Steinar, were you able to view my post? Has Closed Captions files been implemented as of yet? Let me know, thank you!
Hi Timfx, thank you for using FFAStrans and welcome to the forum! :-)
I'm sorry but closed caption is still not supported but I'm aware of the request.
PS: I deleted your top-post on the same topic.
