%recursed_path% Variable Is Not Being Populated
Locked
Hamper
Post by Hamper » Tue Dec 10, 2019 1:11 pm
Hey Guys,
I have been testing Bata 3 and i have come across an issue where the %s_recursed_path% variable is not being populated, when i print it to a text file to check it is just an empty string. I have tested with 0.9.4 and it works as expected.
Thanks again for your work in releasing this beta, so far this has been the only bug i have come across in our post production workflows.
Cheers, James
Re: %recursed_path% Variable Is Not Being Populated
Post by admin » Thu Dec 12, 2019 5:30 pm
Hi James, thank you for using FFAStrans and welcome to the forum! :-)
Are you sure %s_recursed_path% is not working? I just tried it and it works here. You have checked the "recurse" option in the monitor? If so, could you export and post your worklow?
Hamper
Post by Hamper » Sat Dec 14, 2019 4:45 pm
Hey Steinar,
Yes recurse option in the monitor is checked and i can't see where i'm going wrong with it!
Here is the workflow as requested, Thanks again for your support with this!
Cheers, James
DNxHR Test.zip
(1.39 KiB) Downloaded 66 times
Post by admin » Sun Dec 15, 2019 9:58 pm
Hi James,
I found the bug and it will be fixed for the next beta version (5). Thanks for reporting! :-)
Locked
