Issue between FFastrans service and API
Re: Issue between FFastrans service and API
Post by admin » Mon Dec 02, 2019 8:53 pm
Hi Ben, is it still ok?
Post by momocampo » Mon Dec 02, 2019 8:58 pm
Hello Steinar,
Yep always ok for the 2 workstations. Very weird...
Can I ask the difference between the exe_manager.exe original and the one you give me? Do you want I try again with original file?
Thanks Steinar ;)
Benjamin.
Post by admin » Tue Dec 03, 2019 10:04 pm
Well, the difference is a bit in the technical area.... It was a method for keeping the API running if it failed to respond. If that happened exe_manager would force restart the API. However, it was very unforgiving and so I changed the behavior to not be so brute. Although your servers run fine now I'm not 100% that this was the issue. So if you could revert to the previous exe_manager version, just to check and so that we can find out? And leave your restart script off ;-)
Post by momocampo » Tue Dec 03, 2019 11:33 pm
Thanks for the explanation. It's ok, I'll try to switch the exe_manager by the original to see what is the result. I'll be back to write a feedback.
Locked
