Maybe the first bug
Maybe the first bug
Post by momocampo » Tue Nov 12, 2019 2:00 pm
Hello Steinar,
I just begin to use this beta version and maybe I found 2 issues:
- First : We can't delete connection with left click mouse. Is is normal? We can with ctrl button otherwise.
- Second : The copy-paste was improve and keep nodes order inside a workflow (left to right) but if we copy and paste in other NEW workflow, the order is up to down...(if copy paste in an existing workflow, it works).
Hope it helps.
Thanks ;)
Re: Maybe the first bug
Post by admin » Tue Nov 12, 2019 5:11 pm
Thanks for reporting, Benjamin! :-)
The first "issue" is not an issue, it's by design. There are some technical and performance reasons for this but also a few user reasons.
- The method is more in line with the method for deleting nodes.
- The user can more freely press "anywhere" and move the workflow contents.
- The user wont accidentally delete nodes.
The other issue is more an issue but not necessarily bug. If you copy to a workflow that already has nodes is works as expected, but if the workflow is empty the copied nodes are inserted top -> down. However it should be trivial to change this behavor.
Post by momocampo » Wed Nov 13, 2019 9:01 am
Hello Steinar,
I thought well I could not delete connection more for security than anything else. It is a good idea and I have to admit I have sometimes deleted connection by error.
About copy-paste, happy to understand how it works now :)
Thanks for explanations.
Post by admin » Thu Nov 14, 2019 5:22 pm
Great, I have changed the copy/paste behavior now so that the pasted nodes are always left -> right.
Post by momocampo » Thu Nov 14, 2019 9:36 pm
Damn!! I hope everyone prefers from left to right otherwise I will not make friends :lol: :lol:
It's really kind Steinar, I appreciate so much.
Thank so much.
