converting workflow does not run
Locked
jerrysub
Post by jerrysub » Wed Jan 22, 2020 4:08 pm
I tried to import workflows from v0.9 but it won't be possible.
1st v0.9 export as xml
2nd new v1 import as json
did I miss something?
then I copy workflows folder from v0.9 to v1.0 but they are not converted, what is the right process ?
br,
Jerrysub
Re: converting workflow does not run
Post by momocampo » Wed Jan 22, 2020 4:35 pm
Hi Jerry,
Here is the link with upgrade procedure : viewtopic.php?f=8&t=974
Beware to backup all your files from 0.9 before doing upgrade.
Follow step by step and it will be ok.
jerrysub
Post by jerrysub » Thu Jan 23, 2020 4:24 pm
Hi Jerry,
after installing tools for "Microsoft Visual C++ 2010 Redistributeable" all is working as expected.
thanks,
Jerrysub
Post by momocampo » Thu Jan 23, 2020 9:44 pm
Hello Jerrysub,
Happy to hear that everything is working well now.
Have fun ;)
jerrysub
Post by jerrysub » Tue Feb 04, 2020 12:09 pm
waht about the fact to not be able to import xml to new version ?
br,
Jerrysub
Post by admin » Wed Feb 05, 2020 9:50 pm
Importing legacy xml workflow packs will be available in the final 1.0.0 version scheduled for release 14. february.
Locked
