H.264 Encoder Issue
dwdotco
H.264 Encoder Issue
Post by dwdotco »
Hi all,
Having some audio issues with the h.264 encoder..
Firstly, for me, the audio layout won't save (I've seen this same issue reported before with a different encoder), selecting a different layout and clicking OK works, then when returning to settings it switches back to 1x2. Saving the workspace and looking at the .ini it seems the actual selection saves, not sure if it uses it though when running tasks which leads me to my second issue.
For me, after encoding in h.264 the audio only plays in the right channel.. this is my main problem at the moment, any help would be greatly appreciated, I'm not sure if this issue is related to the first issue?
Many thanks! :)
Re: H.264 Encoder Issue
Hi dwdotco, thank you for using FFAStrans and welcome to the forum! :-)
I can confirm the bug that cause the "H264"-encoder to be locked on 1x2 and it has been resolved in the upcoming 0.9.1 version.
I have also had other reports about audio only playing on the right channel but I'm not able to reproduce in 0.9.0.4. Is this the version you are running? There used to be an issue with the first channel in the initial 0.9.0 release but it was resolved in the following patches.
dwdotco
Post by dwdotco »
Hey steinar, many thanks for the welcome and fast reply :)
Glad to hear it's a known bug, will keep an eye out for 0.9.1, also - yes, I'm running ffastrans.exe 0.9.0.47 on windows 7.
Cheers!
0.9.0.47 is not the latest. The about should read:
FFAStrans.exe 0.9.0.64
processors.exe 0.9.0.28 (This is the important file)
exe_manager.exe 0.9.0.12
def_runner.exe 0.9.0.8
rest_service.exe 0.9.0.12
Can you please make sure you have applied the latest patch?
dwdotco
Post by dwdotco »
Hey steinar,
All sorted now, it seems I wasn't running the latest version, oops! Many thanks for your help.
P.S there's a typo in the 'resize' dropdown for the 264 encoder, it reads 'stretch and loose aspect' instead of 'lose'.
Thanks again :)
Thanks for your observation! English/US is not my native language som there are certainly some typos here and there.
kratt
Post by kratt »
Just a note.
Version 0.9.0.17 and H264 encoder.
Input file has 8x mono streams. First 4 have audio contents, rest is empty/silence.
Output file has a nice stereo mix but left channel gets like -10 dB.
The filter for my case is :
-filter_complex "[0:1]pan=1|c0=c0,alimiter=0.070859:1:0.9:0.1:level=0,aformat=s32:48000:1[a1],[0:2]pan=1|c0=c0,alimiter=1:1:0.9:0.1:level=0,aformat=s32:48000:1[a2],[a1][a2]amerge=2[astr1]" -map "[astr1]"
-c:a aac -ar 48000 -b:a 256k
Maybe this is intentional because the encoder does not know if it should mix those empty channels or not.
Hi kratt, thank you for using FFAStrans and welcome to the forum! :-)
This issue has been solved long time ago (0.9.0.1 released 23. February) so you need to upgrade ;-)
